- Jul 21, 2013
- 65,062
- Plaster
- Pentair Intellichlor IC-60
1. It includes 1 pump, but with the water features and and slide it will require a second pump to make everything operate as it should.
So the ePump for the pool and the Stealth pump for the slide?
2. Chlor is short for Chlorinator
Thank him for that enlightening comment. Is that a Trichlor tablet chlorinator? You don't want it. You want a SWCG. Using Trichlor to chlorinate your pool will continuously add CYA/stabilizer. The only way to remove high levels of CYA is to drain your pool. So if you use Trichlor you will be draining water from your pool every few months.
3.The extra pump is for the water features and slide
OK. And what valves will you have to control the water features and slide? You want all diverter valves. No ball valves.
4. I believe the line your looking at says drain "pots" rather than spots. the drain pots are the main drain assembly. we use an extra one in order to remain compliant and for safety reason.
OK.
5. the 3/4 inch line is used as a fill line that will be connected to an automatic filler device
ok.
6. 1 1/2 lines are used as return lines for the pool and the suction will be 2 inch
OK
7. the spa is plumbed in 2 inch and reduced down for the jets.
the flow rate all depends on what you have your pump set at. with it being a variable speed pump you can adjust the flow rate.
these are no a jacuzzi with jet pumps, these are a spa which operates off a circulation pump.
Ask him what the maximum flow rate you can expect to get from each spa jet will be?
For a strong jet feeling you want it to be 12-15 GPM per jet.
8. were going to be going from a CL460 to a CL580
Good.
9. on the pool plans that i have im showing 2 LED lights in the pool and 1 in the spa. I would like for you to consider adding a third one in the pool since it's such a long pool
What model LED lights will be used?
10. All pools that i build, i make sure have an overflow drain, especially in this area. i do my best to hide them inside of a skimmer
Good.
11. i think the black would look great! However there are other options. We're somewhat limited in color choices. we have white, light gray, dark gray.
Coordinate the color with your plaster, tile, and coping colors.
OK.
ok.
OK
Good.
Good.
