This our second season with our IG vinyl lined salt pool with sand filter. Every since it was installed, the water level in the pump filter very slowly lowers over the course of a week, with the heater and SWG eventually noting a low flow message. After I backwash, it returns to a full pump filter and the process repeats itself over the next 6-10 days. The robot vacuum cleans the pool regular (we don't get a ton of debris) and I empty the skimmers every couple days. The pool company has checked for air leaks in and around the pump and it appears sealed. The sand filter pressure normally sits at 16 and after a week when it needs backwashing again it only goes up to 18 so not a significant pressure increase.
I'm at a loss trying to figure out what's causing this as it doesn't seem like it should be normal. There's no issue with the jets and the skimmers appear to be doing their job, although after a week when it needs the backwash the skimmers are barely pulling water.
Hoping someone has some thoughts! I'm wondering if it could be an issue with the sand filter, or after the sand filter.
