Hello All, I've been looking to upgrade my Flotec AT251001 single speed pump to a variable speed pump. I found someone on Offerup who was selling a Jandy VSSHP220AUT for $600 and bought it last week. The pump is new out of box (he says he installs new pools and has some extra pumps listed on offerup). My worry is if this pump might be too strong or might create some issues. obviously the pump is much stronger and has a higher HP, but i thought "i don't need to to run at full strength anyways"
One of the main things I'm worried about is my current pipes are 2" and the inlet/outlet for this one is 2.5", will i have issues if i use an adapter? I could easily make the discharge pipe 2.5" going to filter but my gut feeling is that suction and discharge should stay the same size, or am i wrong here?
The next concern is the booster pump, I have the Polaris PB4-60 and i noticed that if it is hooked up to the Auxiliary port on the Jandy, it wont turn on until the pump hits 1725 RPM, is there a chance that the pump wont hit that speed because a lower rpm is enough? Right now it is controlled by an electromechanical timer, but it would be nice to have the pump control it
And the last concern is the filter its a Hayward C3025, but it seems it should be able to handle up to 122 GPM. I was worried it might cause some damage.
Please let me know what you think, the only other thing i think i left out is the pool is right around 25,000 gallons, no water features or heaters or anything else. I also purchased an IQPUMP01 on eBay for $60 so i do have a controller for it. If you think i should try to return it then alternative pump suggestions are welcome. (I just saw the black and Decker VSP on amazon for $660 and its what got me double guessing myself )
If you got down here, thank you for taking the time to read my post!
