NO WAY!! That DOES sound like you MIGHT be getting plaster tomorrow for sure!!! SWEET! I hope you wake up to the sound to trucks in your driveway tomorrow!!!!!
Kim
Kim
Sweet! What brand and color?
They plastered and acid washed in the same day? Looks great btw.
When they do something they do it FAST! NICE!
Do you know to NOT turn the water off before it is done filling? You can take one hose out or slow the flow down but do NOT turn it off. It could cause a line in the plaster if allowed to sit at one level for any length of time.
Kim![]()
Almost there! Can't wait to see the slide in action. Would you mind taking pics of the permanent installation (bolts, plumbing, etc.) of the slide so I can see how difficult / easy it is if we add one later. We are considering the S.R. Smith Typhoon which is a smaller than your TurboTwister.
Good to know.....now remember that the water may look a little green in the beginning but that will go away as the levels get balanced. Get your shoulders ready for the brushing!
Kim![]()
No problem I will also find a link for the video install from SR SMITH tonight.
I've seen the S.R. Smith installation videos before. It looks pretty straight forward but I'd like to see how the holes are drilled for the anchor bolts and if an adhesive is used at all (in addition to the bolts). The pool's almost full! Are you'll going to jump in this week/weekend?? It may be a little chilly but might be worth it.
Where in Pearland are you? We're in the Meadows of Southdown subdivision behind Dawson HS.
