Is this even available to buy? Seems all the online stores show it as no longer available.
thank,
thank,
Rangeball said:Are you using a skimmer sock over your skimmer?
They work really well, grab the pollen before it hit's your filter and are cheap![]()
AnnaK said:Take a look at my writeup about the PoolSkim at the link in my signature.
AnnaK
My pool water level varies quite a bit during the course of the summer.
Titanium said:diaplant,
What is quite a bit? My pool can vary up to 2-3 inches and the PoolSkim can easily handle this. The PoolSkim could probably handle 3-5 inches of water level variation with no problem.
Titanium
chrisa said:we are also using our solar cover and just remove the hat/cap...I need to do what Anna said and trim our cover around the poolskim.
MeSue said:If you don't want to cut your cover for some reason, it helps to tether the hat to the base and then it is always close by when you remove the cover. We tethered ours and just let the hat part hang out under the cover when the cover is on.
