Gunite pool Arizona brand new start up.
CombatVet13
64
Mesa Arizona
Good day all,
Day 3 after pool company came to start up my brand new pool. (Details are in my signature)
I believe they did an acid start up.
I have three 3” chlorine tabs floating. Water is clear, ph is ideal level. However I’m not registering a chlorine level.
How to proceed?
I look forward to becoming a supporting member of TFP.
kimkats
44,703
Tallahassee, FL
Bruce, You will also get a discount on the TF-100 test kit when you become a supporting member! That is THE test kit for pools as it has more of the regents we use the most.
Does your 5 way test CYA? Do you know if they added any CYA? The tablets will add some but slowly and not much at a time.
Kim:kim:
YippeeSkippy
12,993
Evans, Georgia
Ok, but that's not gonna cut it. The 6th test is missing
I believe it won't test for FC or CCs, but only give you the TC? Is that right?? And I believe its missing the CYA test, or is that in there??
Fast7
201
Plainfield, IL
Yeah, unfortunately your test kit is not adequate.
It will test FC but only up to 5 ppm and it's a color matching one, which is harder to judge than counting drops.
Also it can't test for stabilizer (CYA) which is vital.
It's also missing Calcium Hardness (CH) test, which I belive it's also vital for your type of pool.
Get TF-100 or Taylor k-2006C test kit.
Reactions: kimkats
