This is to make a long story short. I had crystal clear blue water for a month. Discovered a very small leak in the pool, not worthy enough to make a priority to fix. Was just topping off the water when it was looking low. Filter was always able to run. Then one night I fell asleep and overflowed my pool for 5 hours
Ok. Was back to square one. Rebalanced everything. Was told my TA was low and added baking soda. My water was a clear teal. Then the hole got bigger and had to force myself to jump in to patch and the ground was flooding. Had to then refill. Which it got down past filter and sat for 2 days.
It then had a terenchal downpour of rain after I fixed and refilled. In a day my pool was lime green. I shocked it x3. The next day it was dark green, going to black side…..
Took a sample to pool store. They told me everything was balanced except ph was 8. Add low and slow bioguard. I did that and recirculated pump. Within 2 hours pool turned back to the all familiar teal.
I retested water today. TA 80-100, ph 7.8, free chlorine is at least 10 (highest test will read) as well as total chlorine 10 (highest test will read). CYA is 0. I know. So I added stabilizer. I’m hoping that will bring the ph down enough to let this chlorine do something. I am so frustrated. I want to throw this pool away so bad. I can’t afford a commercial pool right now. But this thing has been one headache after the other. Currently have the filter recirculating after adding stabilizer.
