Just took off the cover and it’s green. do I do the normal shock? With that I mean do I use the pump. Just wasn’t sure if I should run the green water through a clean filter. Thanks guys.
Hey! Thanks! I’ll try that.Hi fellow long islander. Here's a tip that could help next year. Do not open your pool in June. Open it in April like I do and the water is crystal clear. Also close it in late October and bring it up to roughly 15 FC and then close it so there is still some chlorine left when you open it.
Like Marty posted, follow the SLAM process. That pool will need a steady dose of bleach. No need to turn on the SWG until the pool is clear. It won't bring the FC level up quick enough. Save the cell and just give it bleach and a lot of it. Make sure you have the proper test kit TF100 and don't go to the pool store to get the water tested
Yes it's fine to run the green water through the filter.
Yes. Kiss one and your financial situation might improve greatly.i have these tad pole looking things swimming in here! does this happen
Also yes. Stir the water good for 20 minutes any time you want to test, and again afterwards before re-testing to ensure your adds reached their target. (Except for CYA, that can take some days to fully mix)Also should I run the filter for a little bit before testing the water?
What is your TA? If above 50 ppm, do not worry about the pH as long as in the 7's.I added 11oz of washing soda to increase my PH from 7.0 to 7.2.
So I don’t clean it right after the pool clears up? I wait until the pressure rises from my starting pressure of 10psi?
Yes.Is that ok to add my salt and other stuff?
Oh i can do an FC test that way? I usually use 25ml and two scoops of 0870 and multiply amount of 0871 drops to clear by 0.2Yes.
Do your FC test using 10ml of water. One heaping scoop of R0870. Each drop of R0871 to clear is 0.5 ppm FC.
