Welcome!
Honesatly, I suspect you have both problems - algae and iron. Cloudy is the algae and of course ice tea is the iron. The Natural Chemistry isn't doing much other than change colors. So here's what I would recommend:
1. Address the algae and overall water chemistry first. Do you have a TF-100 (link below) or Taylor K-2006C test kit? Seeing a full set of test results from one of those would be step #1 for us to help guide you. For algae we follow the
SLAM Process to kill and remove algae. A simple shock here or there does nothing. The
SLAM Process works, and you must do that BEFORE addressing the iron staining and/or color changes.
2. While battling the algae, the elevated FC level will aggravate the iron. That's a perfect time to filter as much of it out as you can. See the link below from another user who used polyfill to help with that. That's a must as well.
3. Once the
SLAM Process is complete and you've pass all 3 SLAM criteria, you can let the FC level fall to normal as noted on the
FC/CYA Levels and treat any residual iron with a good sequestrant, and of course continue to filter as much as possible.
That's a basic get-well plan. If you have any questions, let us know.
We filled our pool from our well. We knew the risks and knew we would have a battle when the water was 12" deep as it looked green from the metals. Our fears were confirmed when we added chlorine and the water turned brown almost immediately. Enter 5 gallon polyfil filter. It worked...
www.troublefreepool.com
