We have intex pool and there is so much fine debris..we will be vacuuming and ruining our filter until July the way it looks...any suggestions? We don't have a waste valve on our pump
That does make it a bit more difficult. I'm the same way. I just means more brushing and vacuuming. Ugh. Are you trying to follow the SLAM Process at this time to kill/remove algae? Hopefully you have one of the recommended test kits - either a TF-100 or Taylor K-2006C. Follow the SLAM Process and you'll get it. Unfortunately with no way to vacuum to waste, it's a matter of manual lifting.
