- Aug 20, 2020
- 7,811
- Plaster
- CircuPool RJ-60
You are right, after owning this pool without incidence .. I have truly met my first rodeo and have been thrown right off the buck! To my defence, even the so called pool pros and chemist were thrown off too. I am not sure if running my pool without a filter is wise or not, but right now its either tha
This is the point where you have to decide who you trust and just follow one set of directions. You’ve got a chemist who is wrong about algae being present in water that may have copper in it. And a pool service that put in some unknown product that’s causing your filter to clog every 5 minutes. I’m assuming you had to give both of those folks some cash for their advice?
Or trust the TFP advice and get your chlorine up at a sanitary place before it gets worse. Don’t waste your time and money mixing and matching advice, it’ll lead you down a bad road.
