dakhath
0
So....do I just stand pat on the chlorine for now? Also, anything to speed up the clearing of the cloudiness? And, Idon't really think I am going to have enough reagent to do many more chlorine tests, at the rate of 63 drops at a time!!��. ?????
Your Taylor K-2006 is a great kit when everything is in balance and will last quite awhile.
However, as you have found you will burn through those chemicals quickly when doing a SLAM.
This is why the TFP method is so great. It helps you avoid having to do a slam as much as possible.
But when you have an issue the people here are awesome at giving help.
There is an awesome source for more of those chemicals.
Try here...TFTestkits.net.
Under the K-2006 refills look for the XL option.
It is an extra large refill of both the crystals (R-0870) and the R-0871.
Perfect for those doing a SLAM.
You'll also find refills for the other items in your K-2006 test kit.
Some people swear by the speedstir when it comes to testing.
I do, as it makes the swirling of the test water so much easier.
SpeedStir Magnetic Stirrer - YouTube
One more thing....
When doing your FC test at 10ml, you only need to use a heaping scoop of the crystals (R-0870).
You don't need to use two scoops everytime.
You just need the water sample to turn a nice shade of pink.
