I have this gray sand on the bottom of my above ground pool. Some of it is stuck to the vinyl and needs to be scrubbed off. I've seen other threads about this but I can't find one with my exact circumstances. I have a sand filter with a paper cartridge filter downstream of it. I had the volcanic sand in the filter from when the pool was new 8 years ago. The gray sand problem only started happening about a year and a half ago. I thought it was because the sand was getting old and breaking down and passing through the laterals but couldn't figure out how it was getting through the cartridge filter. BTW this sand is completely absent from the cartridge filter as well as the filter housing. I replaced the volcanic sand with silica sand 1 week ago. I removed the lateral assembly and checked it for cracks and damage, none found. The exact same gray sand is still collecting on the bottom of the pool. If it is from the sand filter, how is it getting past the cartridge filter and why is there never any residual sand in the filter housing? If it is not from the sand filter, then what the heck is this stuff? It isn't the same as the dirt from the environment around the pool, that dirt is brown. Any help would be appreciated.
