Hi All. It's my first post, and I apologize for the length. I want to be thorough enough to solicit help and hope to help others who have a similar challenges. I tried like heck to find posts about similar setups in prep closing this fall, but I had little luck. Here goes nothing...
This is my first pool. It's an AG 18' x 33' with vinyl liner. I'm in CT with cold winters and frozen pools. I have an "Ultimate Winter Pool Cover" with a mesh stripe down the middle that allows water to drain through. I think what has me pulling my hair out a bit is that most of the winterization info I found applies to solid covers and very little mesh info applies to colder climates.
When I closed I drained to 6" below the lowest inlet/outlet (the skimmer opening) and put in two 4' x 8' pillows. I was careful about placing the pillows. Since the only permeable portion of the cover is the stripe running down the middle (the long way), I was careful not to obstruct the stripe and to make sure the cover would form a valley down the center under the weight of precipitation, allowing water to drain. I secured each of the pillows along the edge of the pool, at each of the far ends. I didn't plug the inlet/outlet, and left the valves open. My thought (right or wrong) was this would allow water to escape as it collected and prevent overfilling if we got lots of rain and snow.
Now, the pool has refilled almost to the bottom of the skimmer, one of the two pillows has deflated, and there is a solid layer of ice. The combination of these things are where most of my questions come from...
1. Does the pillow orientation that I used seem OK to others, or are they only effective when in the middle of the pool?
2. Should I be concerned that one off the two pillows has deflated? With the pool already frozen, I realize there's no much I can do about it, so I guess this is just more of a curiosity.
3. I'm second guessing my choice to not close up the inlet/outlet. I'm wondering if this might lead the components to crack. On the flip side, I'm not sure how I'd drain water from the pool if became overfilled. Seems like a Catch 22 to me. I'd love some advice.
For anyone who made it this far, thanks for sticking in there! I'll be truly grateful for anyone who is willing to share some wisdom with me. The conversations in this forum have been a lifesaver so far.
Cheers,
Kyle
Cheers,
Kyle
