AquaPlus is ProLogic and takes a GLX-PCB-PRO.
AquaLogic is an older model that takes a GLX-PCB-MAIN.
How old is the box?
Welcome to TFP.
Open up the case and look at the board. There should be labels with part numbers on the board.
AquaPlus bundles ProLogic with the SWG system.
I will shut off the electric and take the board apart to see right now.
I suspect that the board was replaced with the wrong board at some point. The original board was a GLX-PCB-PRO.
I think that the stands that hold the display are different spacing for the two different boards.
Does the display sit correctly on the plastic stands?
Aqualogic Losing Time?
The time setting on my aqualogic control panel keeps changing It's hard to get the pumps to run at the right time when the time keeps changing any ideas?www.troublefreepool.com
