New pool just built. Want to know if the water should go through the salt generator and in-line chlorinator before going to Glacier Cooler? Worried about wear and tear on cooler parts.
Originally the pool builder had plumbed it so when you turned the valve to send water to the cooler it never went through the salt generator and in-lIne chlorinator. Definitely didn’t think that was right water would be returned to the pool without being treated.
They replumbed it now so that the return water goes through filter then heater with bypass then salt generator and in-line chlorinator to a two way valve - one setting to return water to pool and the other setting to send water to cooler then return to pool. Anyone know if this is right?
