I typed up all of the questions that have been offered in this thread and sent them to my PB. Do his answers make sense? The robot freaks me out a little as you plug it in and then submerge it in the water - goes against everything I've ever been taught.
- From my research, 1 skimmer and 3 returns might not be enough for the size and shape of our pool. What do you think about adding 1 one more skimmer and at least 1 more return
- "the middle and large lagoon does come with 2 skimmers because of the size of the pool" Good.
- The "Legend Auto Cleaner" is a pressure cleaner, correct? Could we swap that out for a robotic cleaner?
- "The legend cleaner is a pressure side cleaner which is what we recommend for vinyl versus electric cleaners because of there weight and the sharp sides on the corners. The pressure side cleaner actually cleans better and faster than an electric cleaner" Ignore him. You'll need to decide who you believe. He is wrong on cleaning better.
- To help with dog hair, we'd like to get the largest filter that makes sense.
- "The filter that will be on your pool will be the large DE filter because of the size of the pool" Get the model # and we'll evaluate if it's properly oversized. But you'll also want to use hairnet over your skimmer and that will keep 99% of the dog hair out of the filter. Don't bother mentioning that to the PB - just confuses the issue.
- For the size and shape of the pool, do you think the 2 LED lights + LED bubbler would be enough to light the pool at night?
- "Two led lights and the 2 bubblers will be plenty of lighting for that pool in my opinion we could always add more if you would like" Good, just make sure he is referring to full size LED fixtures.
- Does the EasyTouch come with the ScreenLogic? Is the IntelliTouch an option, and it is better than EasyTouch?
- "The easy touch does no come with screen logic that is just something that would be additional the easy touch is by far the best over an intellitouch the intellitouch is really just designed for a spa there is not as many functions as an easy touch" That is his opinion. I'll tell you that you don't want the EasyTouch and one of our equipment experts can provide the reasoning. @Jimrahbe
- We need to make sure there is enough grass on both sides of the pool to allow for the landscapers to get their standing mower around the backyard without driving over our pool deck. If we downsized to the middle lagoon pool, and centered it, how much space would be on either side of the concrete in your site plan? Would it be at least 5 feet?
- "As far as the middle lagoon goes the decking layout is totally up to you but you will have plenty of space to get a mower by it without going over the deck." You'll need to evaluate if that is correct but if so, sounds good.
Hopefully that covers everything. Contract signing is tomorrow and I want to make sure we're covered!
