Once you get an amount of acid required to lower the pH to 7.6 from the acid demand chart, you can use poolmath to see what matches.
For example, if the acid demand test indicated that 64 oz of acid would lower the pH to 7.6, you would put 7.6 in the target column and an estimated value in the "Now" column.
If the amount of acid is the same, then you know that the Now column is correct. If it's low, raise the Now value until the amount of acid matches.
Note that the TA and borate levels need to be entered for the calculation to work.
