My pool is closed until next month but I have more or less agreed with my PB for him to install a SWG when he comes to open it. He has a Pentair IC40 with his own pool and recommends I get the same one. That's fine with me. This will be the second year with this pool. I have a 120V receptacle near my pad that he would plug the unit into. I assume the SWG power unit is also tied into the pump circuitry. I was running the pump 24/7 last year, and as that seems to work well with the heater, would probably like to continue to do so. The PB says I could just run the SWG at 20% 24/7 like he does with no timer. This confuses me. If 20% turns out to be too little and 40% too much, then what would my options be? Could I or should I use some kind of timer on my 120V receptacle to run the SWG something like 18 hrs. at 40%, if that turns out to be the sweet spot? Can the pump RPM/flow be adjusted to help? Should I not have more precise control over the CL in my pool?
