- Nov 12, 2017
- 12,636
- Plaster
- Pentair Intellichlor IC-40
VERY neat! First thing I noticed!!
There are some vocabulary issues. James is using a power supply. It's not a transformer (though likely contains one). I provided links to power supplies, but then used the term transformer incorrectly in a previous post or two. Sorry about that. Yes, the OP needs a 24VDC, 1A power supply to run the IpH pump. He shouldn't try to get that power somewhere off the motherboard, for sure. If James can corroborate that the one I suggested is working for him, then the OP is all set on the choice of part. But, and pardon me if I'm misinterpreting, it seems the OP might not quite understand what an ET relay does, or how to wire one up: input, output, load, etc. So I concur that if he's not comfortable with the language, or concept, or wiring, that he find someone that is to help him (onsite). Those mother boards are crazy expensive!!
And yes, James, if it was my setup, I'd want another layer of protection!
I love your egg timer idea. But I'd add a flow switch, wired in series with the pump and relay (are there 1A, normally open, flow switches?), so that both the relay and the flow switch would have to be closed before acid injects.
Can the ET be trusted? Can any timer? Even the one that comes with the IpH (which has built in max-dosage safeguards built in)? We roll those dice. Just yesterday, with everything off (in between schedules) I launched ScreenLogic on my iPhone to dial down the runtime hours for my filter pump (too much SWG action going on this time of year). A minute later I hear my solar system filling on the roof. My filter pump is running and solar is engaged. I turned neither on, nor was either scheduled to come on just yet. All I did was edit a schedule in ScreenLogic! I've experienced similar, uh, inconsistencies before with my ET scheduling. So using an ET to pump acid is not without some risk, I think it is fair to say.
Now, my IpH controller could just as easily fail, and send 24V to my IpH pump until the tank runs dry. So nothing is bulletproof. Ha, for the first month I had it running, I checked the pH just before my kids got in. Ya never know!
My ultimate safeguard is the size of the IpH tank and the 1:1 dilution I use. If it failed on day one after filling the hopper as full as I ever do, my pool would get 1.5 gallons of 31% MA. I'd get a free exfoliating scrub, and my pool would get one, too, but I think we'd both survive.
