Valves are turned correct but it’s not drawing water into the pump.
I’m starting to get worried about the process. Since I’m unable to get the leaves out pre draining I’m worried the pump will just get clogged constantly.
What is the best way to drain when you have debris? Should I start the pump in the shallow end and move it as I clean out leaves?
We are to the power washing part of our journey! It took a lot to get all of the solid stuff out.
Yeah I would not let you put that YUCK in mine either LOL Good job so far! Now I would go ahead and put some chlorine in the water as it is fulling to kill the left over stuff. The hose adding water will mix it all up good.
That does look oh so much better!!! I can't wait see your first float with an adult drink in hand! OH and the kids first cannon ball!!
Kim![]()
Test results 6/5 8:30am
FC=3ppm
CC=8ppm
pH=7.6
CYA=0
The test kit was overwhelming at first because there is so much stuff in it but then I realized the rows are organized by test you are doing. I think I did the FC correct, it was hard to get the water to turn pink. I had to add 3 scoops of the DPD powder to get a reaction and then it was 3 drops to clear it. I used a 25ml sample so it should be 3 drops x 1=3ppm.
I didn't have time to do the TA or CH readings. I assumed the ones I did were the most important but after putting everything in my pool math app I should have tested at least the TA.
K2006 Instructions said:Free & Combined Chlorine Test
1. Rinse and fill large comparator tube to desired mark with water to be tested.
NOTE: For 1 drop = 0.2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample.
