Re: New build in Friendswood now with pics......
We have finally nailed down all the plumbing details (I think.....)
Please let me know if this sounds reasonable:
All pumps are the Intelliflow 4 x 160
Pump 1 (main circulation):
Suction piping:
2.5" from main drain and
2" from each of the two skimmers
2" suction from spa
All suction piping goes all the way to the pad
Returns:
2.5" to loop around pool (which will be 2") - 5 returns from that loop into the pool
2" spa return which will feed 4 leg jets and will also be used when we want to heat the spa
2" for bubbler on tanning shelf (will probably be throttled way back most of the time)
All flow coming through pump 1 will go through the filter (Quad 100 DE), through the heater and the salt cell (IC60).
I did, however, think that 90+% of the time we will not be using the heater so it seemed wasteful to go through the heater all that time and paying for that head loss. The PB agreed to put in a manual valve to bypass the heater. Does that sound reasonable?
Pump 2 (spa pump): 2.5" suction from spa and 2" return to the 2" loop around the spa feeding the 8 jets (not going through filter or heater or anything else)
Pump 3 (water features): 3" suction from closest place in pool
Returns:
One 2.5" return to each of the two 6' rainwalls (separate runs all the way)
One 2.5" return feeding the two 2' sheer descents (splitting off near the pool)
PB also agreed to make all 45 Deg bends - no 90's. I think that is a very good detail.
There will also be an air pump (I think they said 2 HP) and the cleaner booster pump (0.75 HP, I believe)
My main concern is the manual bypass of the heater. Have you heard of that before? Should I have a little flow though the heater to avoid stagnant water?
Obviously, it is critical to remember to turn the valve to allow all flow through the heater when we want to heat spa and/or pool.
If the weather behaves we should start digging this week. We can't wait......
I will start taking pictures when there is something to look at........
