G
Guest
yes! I quite agree!Buggsw said:Just wanted to say it was nice of you to share your program. Thanks.
jefeyessica said:I'm having trouble downloading the file. When I click download, the file is downloaded as an EFW file (CA security file). I don't know if it's because my CA virus security thinks it has a virus, or what.. Do you have any suggestions as to how I can get to the software?
CA anti virus does that. change the extension back to zip and you are fine and change your antivirus to a better one. I would suggest Avast!jefeyessica said:I'm having trouble downloading the file. When I click download, the file is downloaded as an EFW file (CA security file). I don't know if it's because my CA virus security thinks it has a virus, or what.. Do you have any suggestions as to how I can get to the software?
jefeyessica said:Thanks for this software. I would still like to see a place to document how many chemicals I add, and at what time. Currently I use a notebook with columns: Date, Time, Current readings, Goal readings, chemicals added. With all of these readings I can see if the chemicals I added, actually worked to reach my goals.
Also running it on XP. Created a short cut for the desktop and the splash screen comes up and goes away and is replaced by the dos & main screens.fishoutawater said:Hi, new to form. I downloaded the program and installed it on an XP machine. When I try to run the SW, the splash screen shows up then disappears. Something is running in the background cause when I try to run the program again it tells me it is already running. However, there is nothing in task manager under programs that I can see. Also, I do not know which processes are associated with the program so I can't supply any info there.
Perhaps I messed up the install... Let me know your thoughts.
Tony
Marillion Fan said:Also running it on XP. Created a short cut for the desktop and the splash screen comes up and goes away and is replaced by the dos & main screens.fishoutawater said:Hi, new to form. I downloaded the program and installed it on an XP machine. When I try to run the SW, the splash screen shows up then disappears. Something is running in the background cause when I try to run the program again it tells me it is already running. However, there is nothing in task manager under programs that I can see. Also, I do not know which processes are associated with the program so I can't supply any info there.
Tony
I'm not the most savvy when it comes to downloading programs but this one works ok.
errodr said:jefeyessica said:Thanks for this software. I would still like to see a place to document how many chemicals I add, and at what time. Currently I use a notebook with columns: Date, Time, Current readings, Goal readings, chemicals added. With all of these readings I can see if the chemicals I added, actually worked to reach my goals.
Very good idea. I will add to the next version.
