You have to calculate it to be accurate but you can get pretty close by estimating your total resistance.
Can you find the "pump curve" in your documentation?
View attachment 72561Motors don't determine the flow rate. It is the pump (i.e. Wet End) that determines flow rate. If you don't know the pump make/model, then post a picture of the pump itself.
But in most cases, it really doesn't matter what the flow rate actually is.
I believe that is a MaxEPro P6RA6YF-206L. Most likely flow rate will be between 60-80 GPM depending on the head loss in your plumbing. But again, why are you asking?
The pool school recommends one turnover per day
Can you point out where in Pool School it states that?
We do not focus on 'turnover'. Read Pool School - Determine Pump Run Time
Take care.
That’s where I read about turn over
Heh
Chemically, you need to have the proper level of chlorine distributed to all parts of the pool. However, based upon my own testing, that happens fairly quickly < 1 hr. Plus the run time report in my signature indicates that most pools can get away with less than 2 hours of run time and nearly all pools, less than 4 hrs.
So a decent rule of thumb is that after the first hour of run time, you pretty much have all the FC distributed if you dose manually. If you have a SWG, then you need to run long enough for that to add FC to the pool. After that, it is just about cosmetics and allow the skimmers to remove debris. So yes, it is mostly eyeballing to see if it is clean enough for your tastes.
Turnovers don't matter.
CorrectHistorically, the rule of thumb has been to run the pump at least 1 turnover per day. However, that has turned out to be a very poor indicator of actual required pump run time.
You did not read the entire statement ----------
