Hello TFP - first-time pool owner here and I love all the advice in the forums as I am learning!
After one of the recent storms in TX, one of the pumps triggered the circuit breaker. If I switch the pump on, it makes a couple of loud bangs and spits 2-3 flames from the bottom (see picture), then the circuit breaker triggers again. It seems to be pumping for 2-3 seconds before triggering it, as I can see the water moving. I assume the motor is broken and I found the replacement as Century (A.O. Smith) 2.0 HP Up Rate Motor, Single Speed - Model B2859 (I attached pictures of the current motor and pump labels).
Before I attempt to replace the entire motor, do you think I could repair it instead?
If I end up replacing it, would it be better to pick a 2-speed or VSP for this pump serving just the catch basin/edge waterfall?
Thanks in advance!
Thanks in advance!
