- Jul 3, 2023
- 44
- Plaster
- Pentair Intellichlor IC-40
Hello all, first time pool owner.. set up has a 15K gallon pool + SPA, IC20 SWCG and a 3 HP Pentair variable speed, also a heater. Set up is sweet, there is a control pad in the family room that can manage multiple things including pool / spa mode. My question --> the set up currently has a bypass loop with a valve that seems to partially (30% to 50%?) open. Plumbing seems to have an outer dia of about 2-1/4 inch.
My questions are:
1. I have heard such valves may or may not be needed on a variable speed set up - is this correct? Do I need the valve operating?
2. How do i determine the best setting for the valve? 30% open vs 70% vs fully open?
Thank you all in advance for your help!
My questions are:
