Florida Block-Pool Build
Has anybody seen an update on this build somewhere? I was following along from the beginning and was fascinated with his tenacity and never quit attitude. Just wondering what the status is.
Hi! I'm alive.
I haven't given an update because it's depressing. Tropical storm Debbie came through right before concrete was going down for the footing. It dropped 8-10 inches of rain here, in 2 days. The entire dig was ruined. Now we're in one of the rainiest September's on record, and well, I can only wait until the wet season ends to even think about attempting to get back to where I was progress-wise. Probably November.
  • Sad
Reactions: kimkats and Newdude
Holy cow! Sorry to hear about the storm damage to your dig. Those darn tropical storms, no amount of prep would make a difference. You just have to sit there and watch it take its course.
Hang in there. I’m hoping your dry season arrives early and lasts longer than normal. 👍
Reactions: timjs
We are hear to cheer you on when you are able to get back to it!
Thanks for the kind words! I'll be back at it as soon as possible, and I'll make sure to document as much as possible when I do! :D
Reactions: Casey
The weather has been relatively dry, and the ground water level is now 4 ft deep. I'm tempted to start DIGGIN! I'm going to be patient though because it's still August and I'm no fool. We haven't seen the last of the heavy rains just yet.
I did however change plans a bit. I want some extra length, so I'm drawing up 16x32ft. Also, instead of a constant 5ft depth, I think it's better to go from 6 courses (about 4ft deep) down to 10 courses ( over 6.5ft deep).
This would require a stepped footer which I've never done before, BUT, I'm sure I can handle it.
Also considering 6" wide CMUs instead of the standard 8" blocks only because they are significantly less expensive
Hey I'm a Jacksonville actually orange parker. Anyways I will be in a similar situation as you needing new pool walls. Not sure if your up to it but would like to reach out to get some advice on my future project.
Hi! I'd love to help if I can. The two biggest pieces of advice I can give is
1)Use the "dry season" to your advantage. Once the summer afternoon storms come, you can forget about it.
2)If you're doing this alone, don't even attempt it while trying to work a full time job. I vastly underestimated the time requirement of doing this myself.
As a little update here since I hopped on to reply... I'm currently waiting for the hot weather that's coming soon to lower the water table to a manageable depth.
At which point, I'm switching to part-time at my job. This will give me Thursday-Sunday to work on the pool... whereas last year I worked 6 day work weeks pretty much all year.
I wouldn't even attempt to dig the pool out any bigger. And to be honest after talking to a Brick Mason. I'm not sure I would go this route anymore. Filling every cell for 600 blocks is something like 6 yards of concrete, were at $300 a yard for concrete here. The footer is 3 more yards, Rebar is probably another 2k I'm already at the cost of polymer pool walls with half the headache. Were at I'm guessing around 5k material cost. I would probably have to sub some of the block work out. I'm thinking dig out what I got and re use my hopper. Buy another polymer pool kit and slap it in for another 40 years. One good thing is my water table doesn't start until around 10 to 12 foot im really high up for Florida. It's fairly dry really fast here.
I dont think filling every cell is necessary. I'm only planning on filling the ones that will get vertical rebar, and that's every 3 or 4th hole. One thing to keep in mind is you need concrete even for polymer walls, they need to be locked in once installed. My old poly panels had moved all over the place, which I thought was weird until I got down there and saw there was zero concrete or even gravel behind them.
You want to share any pics of what you got going on?
My pool hasnt fully collapsed in I'm still running it until it does. I have one wall that's busting with dirt pushing. I have an oval pool like you but larger. 17x34. The Brick Mason I talked to stated he dint think every third cell with vertical rebar would be enough. He said he fixed a wall that day (bulk head) were the same exact thing happened. He said the dirt would eventually push the wall. He said horizontal and vertical rebar would be needed. I'm not sure he understands the weight of the water pushing back on the wall but who knows. This guy has done it for 36 years. Admittedly not a pool builder. I could mix and pour the slurry of concrete my self if I had to. The 8 inch collar on the bottom doesn't really scare me there's absolutely no finish work needed. I also found a place that made walls they claimed don't need a concrete collar. That's crazy your pool dint have any concrete locking it in. I wouldn't be shocked if a lot of them dint. In my personal opinion I can't imagine a block wall even with every third or fourth cell filled on a footer couldn't hold back more then these flimsy panel systems. They look thin and dirt cheap. Maybe the engineering and bracing makes them better. But I can't imagine how if they did everyone would be using them as bulkheads and I've NEVER seen a system like this used EVER!
I see where he's coming from, but in the end it's a 4 ft tall wall, not an 8ft tall basement.
Btw, go back to post #7 on this thread. His pool is massive, and the inspiration for me to take on this project. He did vertical rebar sparingly. While he does state he filled all cells, the cells with no rebar in them don't really benefit from a structural point of view nearly as much as a rebar-filled cell. So that's optional. A lot of the research I did for how the plan my walls, I took from researching cmu block basement construction. Because its the same thing, just much less loads involved for a short little pool wall that will eventually be balanced by water weight anyways.
I looked at how his was built. I agree this guy would mortar joint them as well he wouldn't dry lay them. I have an oval with a radius he said that would create another nightmare laying the block on that radius. Could be done but a lot of cuts and labor. I'm still thinking and researching. I also thought about seeing what a monolithic wall system would cost. Unfortunately construction materials have shot through the roof. Although I think we're about to see a starving market for work here soon. We will see.
Oh yeah, keeping the oval was out of the question for me. Rectangle it is. Easier of course but also opens up tons of space.
Reactions: ChrisX
Nice I seen them for under 5k. Definitely a lot easier then shoveling.
I did a "test run" with a shovel when I first started, just to see how much material I could move with an honest effort. It was laughable. What took me half a day with several breaks, the machine did in 5 minutes. And the tree roots... oh how satisfying watching those tree roots just pull right up out of the ground and snap.
Right 🤣. With the wall systems guys can dig out and have the pool in two days. It's ridiculous how much these things are installed.
I was quoted 15k to build the concrete walls. Filll every cell footer rebar horizontal and vertical. I would probably go that direction as it should last a lifetime over flimsy panels.
