You're not alone, but you are doing very well. You numbers look pretty nice. The TA will come down in time. Not to worry or feel pressured about that. When the TA is elevated like it is now, it's very normal for the pH to float upwards a bit quicker during the week. So once the pH hits that 8.0 area, knock it down to about 7.0-7.2 with acid, then repeat every few days as necessary. With a vinyl pool I don't think you have to go out of your way to aerate just to accelerate the pH rise routine, it's not that critical and no need to rush. Overall your test numbers look very nice. If you pass one more
Overnight Chlorine Loss Test you should be algae-free and good to go.
Remember we round-up the CYA, so you are at 80 now. No more stabilizer for sure. Be sure to keep the FC balanced in the proper range as noted on the
FC/CYA Levels. Since the FC was elevated recently, I suspect you are good there as well.
