1. Yes
2. Sure (don’t add it all at once do about 70-80% of what
PoolMath calls for then test it in 24 hrs.
3. Add liquid chlorine {3-5ppm or so & cya (sock method){around 30-50ppm for now- you will test & add more after a day or two to get in the 70ppm range } as soon as u can circulate the water to dissolve the cya - this can be done before or after the salt but you want chlorine in the water asap.
You don’t want to wait for the swg to be up & running before you chlorinate your beautiful new water or else things will begin to grow
You will need to dose w/ liquid chlorine every day until your swg is up & running. It is not designed to get you to target fc levels from zero. Its a maintainer.
4. Like i said above test salt level after 24 hrs then add whats needed - after it has circulated a while you can turn on the swg.
Small additions of salt aren’t as big of a deal so you don’t have to let it circulate as long before turning on the swg.
5.Set the swg for like 8 hrs then test your fc , let that guide your adjustments. If its too low dose w/ liquid chlorine & turn swg up. Too high, turn it down etc. You never want to go below min for your cya
FC/CYA Levels -
6. You won’t have any fc, salt, or cya on the fresh fill but you will need to test ph, ta, & ch to know what you’re working with.
as stated above you will add the fc, cya & salt using 0 as your current amount in poolmath to determine what u need.
You need to test the fc (the fas/dpd test w/ the powder) every day. Test The salt & cya 24 hrs approx. after adding them.
Once u can circulate the water u can adjust ph. Unless Ta is below 50 don’t worry about adjusting it for now.
Adding ch is not necessary in a vinyl pool but you need to know what you’re starting with as too much can lead to problems.
* Take aways… chlorine is paramount!
* post your results here & we can help u along
