- May 3, 2014
- 62,732
- Fiberglass
- Pentair Intellichlor IC-40
Ok. You know your area. Does it flood easily? Near a bayou or other waterway?Northeast.
We don't have a problem with flooding but the pool has no cover and will get a lot of rain water.Ok. You know your area. Does it flood easily? Near a bayou or other waterway?
Were you asking about flooding due to the water table? I thought you were wondering about potential the pool had flood water in it in the past, which it hasn't but we are close to Lake Houston. Any idea what the price range is for a DIY switch to SWCG?Ok. So once you decide if you want to follow TFPC and drain some water, let us know
Draining - Further Reading
www.troublefreepool.com
Yes. If you drain a pool in an area with surface water, the pool can rise out of the ground.Were you asking about flooding due to the water table?
You need to lower your CYA - 120 is just so high that the FC won't be able to manage and keep the pool sanitary. You want it down around the 50ish range, or 70ish for a SWG (SWG can run higher with a bit lower FC and have less issues). So you need to drain a little more/less than 50% of the pool. If your water table is high, you need to worry about the pool "popping" out of the ground due to the hydrostatic pressure on the pool from the water around it. If it's not high, you could do a quick drain of about 50% in the late afternoon, keeping the plaster wet with a hose, then fill it as quickly as you can overnight when the sun isn't on it.Were you asking about flooding due to the water table? I thought you were wondering about potential the pool had flood water in it in the past, which it hasn't but we are close to Lake Houston. Any idea what the price range is for a DIY switch to SWCG?
A DIY SWCG would be around $1000 for your size pool.
Looks like we'll be doing a no drain water exchange. Thanks for your nice summary!You need to lower your CYA - 120 is just so high that the FC won't be able to manage and keep the pool sanitary. You want it down around the 50ish range, or 70ish for a SWG (SWG can run higher with a bit lower FC and have less issues). So you need to drain a little more/less than 50% of the pool. If your water table is high, you need to worry about the pool "popping" out of the ground due to the hydrostatic pressure on the pool from the water around it. If it's not high, you could do a quick drain of about 50% in the late afternoon, keeping the plaster wet with a hose, then fill it as quickly as you can overnight when the sun isn't on it.
If your water table is high, you would do a no-drain water exchange, where you have a submersible pump slowly pumping water out of the pool and a hose/etc. refilling the pool at the same time. The goal is to get your water exchanged while not causing your pool to pop out of the ground and not damaging the plaster finish by leaving the dry plaster in the sun.
Yes!Is the following correct?
1) Regardless of if we switch to SWG we need to replace water.
(To be safe will go with the non-draining method.)
Yes!2) For the immediate future I need to add liquid chlorine? I will reread the info on that. I know there was mention of the % or concentration of chlorine to buy.
With the right parameters, Yes!!3) Pool Math will help me figure out how much to add?
Yes and you can use cal-hypo in your pool4) If we don't switch to SWG or until we do I will need to do Pool Math daily & add chlorine daily? Unstabilized tablets aren't a good option?
Ok, I understand better now. Without switching to SWG I have to put a "bandaid" on every day by adding liquid chlorine. I was hoping unstabilized tablets would do that for me. Thanks for explaining.The saltwater comment was my solution to your exact predicament Last month. I had elevated (95) cya at pool opening this year. The last 2 years I had been using pucks since we traveled extensively. My pool was a salt pool when built and still Has the equipment but hadn’t run it in a few years. I was faced with using liquid chlorine daily or adding pucks and dealing with elevated cya again before the end of the season. I chose to reactivate the swg As the easiest solution for me. After draining 1/2 the pool I was left with 50ppm. Perfect range for my swg. Added salt a Few weeks ago and now back to zero Chlorine addition. Just a cup of acid once a week to control ph.
Cal-hypo?Yes!
Yes!
Yes and you can use cal-hypo in your pool![]()
1) Yes. I do the no drain way. Get it set up properly and it will work fine. You will use more water, but not a huge amount.Is the following correct?
Thank you so much for your help.
It's powder (sometimes a tablet?) hypochlorite, the concern comes with heavy use, because the calcium doesn't "go away", but the chlorine doesCal-hypo?
THANK YOU!!!1) Yes. I do the no drain way. Get it set up properly and it will work fine. You will use more water, but not a huge amount.
2). yes. you can get 10% at Walmart, Home Depot, etc. There is a chemical company in Spring, Napco, that sells 12.5% in bulk.
3) Yes
4) Best is liquid chlorine. You can try the cal hypo compressed tablets. I do not know your current CH so you need to monitor that.
At 420 I’d stay away from cal-hypo too. Liquid chlorine for you!
Your CH is as high as you want to go.
Liquid chlorine all the way.
Fellow Houstonian here. I think you've figured out what you need to do, but just as a sanity check, I think you need to get some liquid chlorine in the pool asap. You do need to drain a lot of water to decrease your CYA, but get that chlorine in there now to keep that water clean.
Once you get your CYA down to a more manageable level, you'll have to decide a path forward on how you want to add chlorine to the pool. Someone else above already laid out your options pretty well. A salt water chlorine generator is by far the most convenient way to do it, but with a big up front cost. Adding liquid chlorine every day works great but is not convenient.
Or you can continue with tablets, knowing that you'll have to monitor your CYA and drain every once in a while.
