Great thanks! Yes, I ran the backwash for 3 min then rinsed for 2. What a difference!
You have your SWCG off right now right?1) I decided to run all the tests this eve and will now ask, is it too early for that? For PH, yes, the high chlorine level can skew the results
FC 19
CC .5
CYA 60 (add stabilizer to bring to 80?) NO, do not raise stabilizer during SLAM Process, it increases your FC requirements
TA 140 (turned blue at 10 drops, pink at 14)
pH 7.8
Salt 3600
Definitely not the algaecide, The "regular" clarifier will also interfere at this stage of SLAM Process, The only thing needed is a can of2) Brown spots are getting fewer and I'm still brushing... any merit to either of these products below to help with water clarity and future prevention?
You can go ahead and backwash3) water level is high from rain to the point above return and I can tell bugs, dirt, etc are not getting into the skimmer. Do I need to backwash to lower water level or wait for evaporation to take its course
OK great -- I'm so ready to get back to normal testing and maintenance but definitely want to do it the right way.
My SWG is off and has been for the majority of the SLAM process.
I have stopped bringing FC back to SLAM level since I believe all live algae to be gone and am just trying to get back to vivid clarity (especially so my wife will be convinced it's "safe" to swim)
My FC this AM is 16. That is down from 19 at 6:30pm last night. (Note: I did the 10ml line last eve, but the 5ml line this AM ... not sure if that matters as far as a variance or not, but still trying to conserve drops unless that is a problem).
I will hold off doing another backwash for now. I will let the filter and brushing and Rover do their thing until Friday, at which point I will seriously consider adding DE or CF over the weekend for a final push!
Can't say thanks enough to both of you and TFP as a whole for the time invested in getting this first-timer back in the water!!
...I have stopped bringing FC back to SLAM level since I believe all live algae to be gone and am just trying to get back to vivid clarity
I did pass the OCLT a couple days ago, CC was at 0.5 and water is relatively clear, which is why I stopped the SLAM.
Just for what the forum calls "TFP crystal clear", the water vividly sparkles! =)I've been pretty consistent in posting pics of the water to show improvement, and I think the last pics I posted yesterday show clear water. If I had to put a % on it relative to "perfect" I would say 75-80%. If I need to resume SLAM I will, but I sure hope I'm past that after 2 weeks!
Thanks!
+1! That is it EXACTLY! Beautiful Kelly! =DHi, Md! Here’s the kind of clear you are striving for. We just want to make sure that once you stop the SLAM, you never have to start it again!
{pic}
