First time poster with cloudy water
Last I put 3 gallons of bleach and 2 hours later the FC was 22. I tested right before going to bed and the FC was still 22. This morning it was 19 if my count of the drops was correct so I added a gallon of bleach and headed off to work.
Reactions: Snoobug and Newdude
Just got home from work and FC is at 17.5 so I added a gallon of bleach. Took a quick pic as a major storm just rolled through. Have a work event tonight but will test when I get home. I took out a bunch of leaves from the storm but a few still remain. Water looks amazing to me.
I just took this pic. I can see the drain in the deep end and some leaves leftover from the storm
Thanks for the advice. As a father of a special needs child I probably have too much patience. Just added another 1.5 gallons of bleach. Time for bed as it’s way past my bedtime.
You’re definitely getting there Vitto !! TFP will redefine what you think clear is. Running out back because the quick glance from anywhere else looked like the pool was empty NEVER gets old. :)
🤬 WHERE DID THE WATER GO ?????
becomes
🤬 THAT is clear water !!!!!
and you go back to whatever you were doing while chuckling to yourself. 3 hours later you’ll be cursing and running again.
