First time poster with cloudy water
Newdude
11,534
NY
Not with the pump running. If it’s well mixed divide the rainfall (1 inch ?) by your depth in inches and it will be 1%-2% at most, probably much less but even on the high side with an absolute whopper of a storm, 2% would lower your 20 FC to 19.6 and be unnoticeable.
Vitto09
60
Goodison, MI
Just got home and pool water is up 2 inches from all the rain. Today was a very hot and humid day and FC just tested at 15.5 and CC at 0.5. Poolmath said to add just under 2 gallons so I added 2 gallons of bleach. I retest in a hour or so.
Vitto09
60
Goodison, MI
Just tested this morning and FC still 22.0. I’ll say CC was 0.5 but it could be closer to zero too as after I add the five drops R-0003 the water maybe barely had a pink hue. Water looks clear as ever so if I’m correct I am done with the slam.
Texas Splash
33,823
Fiberglass
CircuPool RJ-45 Plus
Vitto09
60
Goodison, MI
Just tested.
CH 150
pH 7.9
TA 130
CYA. 60
per pool calculator I added 24 ounces of 31.45 muriatic acid. Also says to add 61 pounds of calcium chloride. That seems like a lot and I don’t have any so it’s time for a road trip.
just took pic of R2D2 in the deep end. Today is an overcast day but water looks super clear
Vitto09
60
Goodison, MI
Thanks to the experienced members here I have my pool back in order and it looks as good as ever but my CH is still a little low at 150. Do I need to be concerned or should I try to get it up.
Texas Splash
33,823
Fiberglass
Water looks great! :goodjob: A CH of 150 is a bit too low for my comfort. I would consider increasing it to at least 250. You might lose some of it in a month or so when you winterize, and the pH will rise in the cold water which helps your CSI, but I still think a little calcium would be a good thing.
Vitto09
60
Goodison, MI
Bought a 25 pound bucket of calcium hardness increaser and will add it in small doses over the next few days. For any newbies reading this, I highly recommend following every word of the experts on this site. No shortcuts. I now know the difference between pool store water clarity and TFP water clarity. Our water has never looked so amazing. Thanks to all that helped.
