First time pool startup
After I get my PH right, should I add chlorine in the evening? Or it doesn’t matter. It is overcast today.
To confirm, you are still green and we are SLAMMING...right?
Print this article out (see link). Read it three times. Follow the process. Any questions after reading, come back...Link-->SLAM Process
Yes I have never seen such a green pool as mine- it’s like a swamp. I had a Dang duck land there last night lol
K another 32oz of this muriatic acid added- still not in range lol (only in range with 2 drops). This algae I had must have made this water have a ridiculously high PH
Lol yeah I think I beat you 😂😂
Lollll idk man
does the muriatic acid stay in the water? Like it doesn’t “decompose” like chlorine? Just want to make sure I’m not wasting any muriatic acid
I would look for some way to confirm your pH test results. Order another bottle of the indicator solution. Your pool store might even have it. Maybe even (gasp) take a sample to the store JUST for a pH test. Don't take any other advice from them.
Reactions: PoolStored
Just woke up and took a new test. It looks like in Finally in range-ish (looks like it would be an 8.4 if I were to guess based on the color). Still need to add more muriatic acid. Did the chlorine test too and it turned a light shade of pink after about 45 seconds. So I think I’m moving in the right direction.
If I bring this to pool store they’ll make me buy the chemicals I need to make the pool balanced lololol
So assuming all of this is going to go the way as planned. And water will be balanced. I still need to get the chlorine tabs right to stabilize the levels? Seems that these liquid chlorine bottles are so much cheaper then the tabs- but maybe the math equals to the same.
Tabs are not sustainable long term. They raise your CYA, requiring more tabs to do the same job. Which adds more CYA and needs even more tabs. No WONDER the pool store lobes them so much. Lol.
So I’ll just continue using liquid chlorine? No more tabs? That would be great news as I spent like $400 on a Dang bucket of tabs last year lol
PS. New numbers.
FC is official 1ppm lol. Finally got it off 0.
I’ll add another 16oz-32oz muriatic acid and another 1-2 gallon of chlorine today
