- Jan 4, 2016
- 5,392
- Plaster
Here's your results, in TFP's preferred format. I'll explain a bit more below.
TC 5
pH 7.6
TA 80
CH 400
CYA 80
Temp 58
TC stands for total chlorine which is the sum of free chlorine (FC) and combined chlorine (CC). You can ignore and not report BR (bromine) because you haven't used bromine in the pool (the test just happens to work for bromine as well as chlorine).
The kits recommended for TFPC are preferred because we prefer knowing both FC and CC. This is helpful for cleanups and for a heads-up when something is going sideways. You can also use less chemicals (saving money) by knowing he correct numbers. Eventually you'll buy a TF-100 test kit, we'll then know both numbers, and you'll save money.
pH - 7.65 suggests a different type of testing; 7.6 or 7.7 (based on your judgement) will work fine for knowing your water chemistry.
TA stands for total alkalinity
CH stands for calcium hardness
I haven't been able to verify if the HTH kit measures CH or total hardness. There's experienced comments here at TFP that suggest both. If it's total hardness, then magnesium hardness would be included rather than removed as it is with better test kits. But your numbers look OK anywhere from 300 to 400, so I think that's adequate information for now.
In the meantime, your water is reasonably well balanced. My suggestion is to use muriatic acid to keep the pH close to 7.6/7.7 (just where it is
) and also suggest adding some chlorine to keep your TC up to 10+ ppm TC. (very dark yellow bordering on orange). Plan for a test kit purchase before swimming season, and your FC can be fine-tuned a bit lower.
Any progress on the filter, high pressure and low flow rate?
TC 5
pH 7.6
TA 80
CH 400
CYA 80
Temp 58
