Hello everyone, this post was transferred from JUST GETTING STARTED and I realized it should be more appropriate for here. Sorry if I occupied more space.
I am probably on the last bus to close the pool in IN area. I have watched many videos and posts on how to close the pool yet still have a lot questions when I found out my pool equipment are different from all those in videos! Please bear me to post the questions one by one here.
First, what is the white pipe for as in picture 1 and picture 2? It has a square-shape plug screwed in one end and a thread in another end. There are four of them left by previous pool-owner. Are they needed for pool winterizing?
Second, I know it is a gizmo in picture 3 and it should be plugged in the skimmer, but the little lid on its top is free to take off or put on. Does it look right? Should I seal it with glue?
Q 3. I will blow air to the suction pipeline. To my understand, to blow the water out of the skimmer lines, you can do it at either end, skimmer or pump end, does it have any difference? For the main drain pipe water, I have to blow it from the pump end. What are the plugs for as in the red circle in the picture? I remembered the pool guy did something to them when the pool was opened, but I don't remember what it was. Should I take them off and blow air to the pipes from here? What should I do with them during the winterizing procedure?
Q4. My pool also has a fountain pipe line. To my understand, I will do the same air blowing as same as other returning pipes and air lock it after pour the antifreeze. Anything else should I pay attention to?
Q5. If the underground pipes will be protected by antifreeze, what should we do with the upground pipes? Just leave them there empty during the whole winter?
Q6. The heater. I noticed a drain plug on the heater. Is it enough to drain all the water in heater by just taking off the plug?
So many questions for a new pool owner like me and many thanks to your help.
