First Equipment Cleaning help
Your VSP won't need any work, but being in the Vegas Valley area hard water may require you to clean your cell. Take a look for any scale deposits on the cell plates. Check your owners manual, but cells are commonly cleaned with a 4-1 ration of water-to muriatic acid soaked for about 10-15 minutes or when the fizzling stops. Cart filters just need a thorough rinsing. Should not need a detergent soaking unless your swimmers have tons of oils or you added some pool store gunk to the water. I'll put some links below to help get you started. Let us know if you have more questions.
