I finished my pool after 2 years of DIY, Plaster (pebble fina) was done yesterday. Balancing going as expected.
1) should i be suctioning the same from skimmer and main drain, or should i be suctioning more from the main drain to catch the dust.
2) presently running VSP at 50% that gives me 70 GPM, and would turn over the water in 4.5 hours. Good speed?
3) Filter pressure at Full speed is about 6, at 50% barley 1 psi. Is this normal? I do expect it to go up with more brushing.
Thanks for all the insight.
