About a year ago my pump was losing suction from skimmer, after investigating I found the skimmer basket was out of alignment. The inner tabs were not inside the 3 slots. So now the problem is happening again only this time after fixing the basket, the pump still loses suction, but not constantly.
When I look inside the pump basket it is full prior to start, then sometimes starts and runs with good pressure. Then for some odd reason the water in pump basket disappears, and pump is sucking air, no water. The skimmer basket is full of water, normal level in pool but no when pump loses suction, no water flowing.
I switch the electric suction valve to spa instead of pool and the pump will prime and run normal again until going back to pool mode.
I cleaned the filters as they were dirty and that seemed to make a difference for 2 days, but now its back to losing suction when in pool mode. Sometimes it runs normal for hours, sometimes a few minutes. So now I need help.
