Hi all. A little history first. Back up a few weeks and we had a filtering issue that was noticed during a backwash and DE was immediately coming out of the jets when putting new powder in. Tore down the filter, no tears in the grids, seals and manifold look good. Clean and put it back together and things looked great for a week. About a week ago I noticed pressures are varying by around 10 PSI with no rhyme or reason. Come out today and pressure is up about 12 PSI and noticed the filter basket isn’t completely full. Not empty but definitely not filled like normal. Start/stop the filter, prime it but still the same result. Put the pool in spa mode and have the same results. No obvious air leaks and unless something is clogged after the jandy valve I don’t see how I’d get the same results with pool/spa mode. Could the filter getting really dirty be causing this already?
