- Nov 12, 2017
- 12,657
- Plaster
- Pentair Intellichlor IC-40
Regarding the "hydro aeration technology"... I don't know anything about that. What I do know, is that nothing is needed in a typical outdoor swimming pool other than CYA and chlorine, a little acid or borax if the pH won't stabilize on it's own, and possibly a little calcium if its too low. That's it. For the last two+ years, all I've put in my pool is: chlorine, muriatic acid, CYA, salt and water. And people. That's it, absolutely nothing else. My water is crystal clear, and 100% safe for swimming. (I adjust CH by alternating softwater (CH-free) and city water (CH-rich), and my TA stays put). Most everything else others will claim about what your pool needs is likely hooey.
Because all those bubbles might affect your pH, I would leave the hydro aeration off for now, and see if you can balance your water with chlorine, cya and acid. Once you're confident you know how to do that consistently, then you can start fooling with the aerator to see if that does anything for your pool. My guess is, it might mess with your pH a bit, and it might look cool, but not much else.
