Here is my scenario.... I am going to shock my well with 3 gallons of bleach to kill an iron bacteria in the water. Between the water column in the well and standing water in various tanks and plumbing, I am looking at about 700 gallons of water I need to shock.
After I let the chlorine sit in the well for 24 hours, I need to pump water from the well until all the residual chlorine is removed. There are a lot of recommendation of what 'not' to do with the hyperchlorinated water, but not many recommendations of what to do with it.
Can I safely use this water to fill my Intex 12x24 (~9000 gallon) pool? If I did the math right, assuming no loss of chlorine, 3 gallons of 6% chlorine in 9,000 gallons would be 21ppm. However the initial feed from the well could be as high as 200ppm. I expect there is no CYA in the water from the well. My thinking is:
1. Fill the pool with ~4000 gallons of water (0 ppm Chlorine)
2. Shock the well with 3 gallons of chlorine (200ppm Chlorine)
3. Wait 24 hours
4. Finish filling the pool with the remaining 5000 gallons (21ppm Chlorine).
Am I crazy?
3. Wait 24 hours
Am I crazy?
