Fill tube?
Cmahon
4
Arlington, tx
I have a PVC pipe that is coming out of the ground near my facet. I ran water thru it and noticed it cam out a hole on the side of the pool. Guessing this was a fill tube at some point. Is this normal and if so should there be more to it than just holding a hose to it?
jblizzle
43,260
Where is the hole in your pool? I have one that's actually coming out of my deck and it is plumbed in to the fresh water supply so I can turn it on and it'll spray water into the pool to refill
ajw22
11,287
Northern NJ
It could have been for a pressure cleaner like a Polaris 280.
A description of your pool and a pic of that area may give us some clues.
kadavis
In The Industry
Apr 5, 2015
1,578
tucson, arizona
You need to tap into waterline and add a valve w/anti-siphon. A picture of the faucet area could help. If you have plumbing skills it should be straight forward.
jblizzle
43,260
Yep that is definitely a manual fill line but is very similar to the one in my 70's era pool. Should be straightforward to add a valve and anti siphon device as mentioned above
