Fiberglass pool
Be very careful draining a fiberglass pool. It is the weight of the water that holds a fiberglass pool in place.
Why can't you do the maintenance on the pool without draining?
@Texas Splash @mknauss
Even in Arizona (where?) I would be careful fully draining. I have but recently use the No Drain when I had to drain. Now that I use softened water for fill water I have not had to drain.
Not sure what you would need to 'clean'.
Maybe clean wasn't the right term, something to use as we brush the walls and floor as it drains. Drained and filled it 3 years ago with no problems. I'm just south of you along the lake, and you know how bad the water is here.
