- Jul 21, 2013
- 54,209
- Plaster
- Pentair Intellichlor IC-60
So I guess I'll be a guinea pig for what happens when non-winterized pool equipment is subject to 20 degree or lower temps for almost 24 hours. When we lost power at 5 am Monday morning, I didn't think it would be out for 22 hours, so this dummy didn't think to go out and drain the pumps and filter. When the power came back on at 3 am today, I thought o Crud, I need to make sure the pumps aren't frozen!!! Too late. And the system had been trying to turn them on for the 5 minutes or so while I got dressed warmly enough to go out (10 degrees in Cypress, TX). Sure enough both pump baskets are solid blocks of ice, and part of the lid lock rings had split in half as if someone had sliced through it (complete circle broken off). So I've got the breakers off, and am going to wait until we get warmer temps later today and then try to pour warm water over the baskets to see if I can get the ice melted enough to pull any big chunks out. Then I'll try to fire up the pumps and pray for circulation.
Open for any other tips you all might have for recovering from bad owner preparation.
I don’t know why you need to rush out and pour hot water on stuff. Your pool is shutdown and dormant. Any damage has been done. Let things settle down and warm up. There is no rush. Once things get back to normal and melt you can assess the damage and get things running.
