FC keeps going down on daily tests
Post up a full set of results, but chlorine demand is not a constant and you should expect demand to go up with water temp and presumably increased usage.
The 28oz of chlorine you added on 6/30 only raised your chlorine by 3.1. I would expect you to lose 3-4 FC daily.
Reactions: harleyl7
I will run a full test today! So 3-4 FC daily is typical?
Ran a test today - my CYA seems more accurate from the last test of 25-30. Last I added CYA it was supposed to be at 45-50.
Based off my results today I was gonna add liquid chlorine of course, but also add baking soda to increase my TA.
Just want to confirm that when I am dosing liquid chlorine. I dose it based off of the top end of the recommend range? So it would be dosing off of 8ppm for FC.
Do I do the same for TA?
Like these images below:
It's best to aim for the high to account for situations that may draw more FC. There's no advantage to hovering just above minimum level. It may take a little more chlorine to get there, but once you're there the daily dose should be about the same.
Reactions: harleyl7
Is that the same idea for TA? Or any other stuff. Like should I aim for the high range of the recommend level?
All your other numbers look good. With a vinyl pool nothing is as important as the FC/CYA relationship. No reason to worry about TA unless it's very high or very low. Just maintain pH between 7.2 and 8.0.
Reactions: harleyl7
Nothing wrong with aiming for "ideal" levels (y)
Reactions: harleyl7
Just add enough baking soda to raise the TA from 50 to 70.
But first, be sure you are taking the TA test to completion.....
Continue to add R-0009 until the last drop does not make a color change, and then subtradt that last drop from the count. If drop 5 changes the color, drop 6 changes it a bit further and drop 7 makes not change - you count 6 drops.
Same goes for the CH test.
Reactions: harleyl7
