Is it feasible to repair an eyeball check valve? I have one of these:
sunplay.com
And there is a black layer (some kind of rubber or similar material) which is the seal inside the spring loaded valve. It seems like I should be able to replace just the black piece with... what? It's decaying- black gooey stuff comes off onto my finger when I touch it, and it's not holding back water anymore. All the rest- the plastic screw fitting, and the metal spring all look good and seem to be working fine. It just doesn't make a seal- can I replace just the rubbery ring and save 32$?
Thanks for your help in advance.
FlaPoolGuy
Eyeball Fitting with Check Valve
Eyeball Fitting with Check Valve, White, will allow water to freely flow when the circulation pump is running and the valve will close when the pump is off.
FlaPoolGuy
