- May 3, 2014
- 58,656
- Fiberglass
- Pentair Intellichlor IC-40
I can guarantee the WG is not measuring at a higher precision. It is a test strip.
pH can move around based on chemical additions, aeration, fill water, excretions from swimmers, etc.
TA of 60 should be good. Your fill water will add TA. When you add acid, only lower pH to 7.6.
You should never have to add baking soda and acid. If you are, you have too much aeration or are lowering your pH too far when it reaches 8+.
