I picked up a 2002 Hot Springs Prodigy as a flip tub. It had been frozen, and has multiple leaks as a result. Hot Springs are the WORST tubs to do plumbing repairs on, due to the piece-built tongue and groove sides and extremely hard foam that channels water, making it a true joy to locate the leaks. But I digress...
I am (obviously) cutting out some damaged pvc, and I noticed that there is a biofilm buildup inside the pipes. This is nothing new to me, having been repairing spas for 25 years, but I thought some of my new friends here on TFP might not have ever seen it. I even hear that some doubt it's existence, and think that Ahh-Some puts stuff in to cause the gunk that comes out.
So here it is:
Here you can see where I wiped some off.
That is a different pipe than the first pic, btw, so you see it is in every pipe in the tub. That's alot of square footage of surface area. And alot of nasty gunk.
A little history... I have never been a fan of purge products. I have tried a few over the years and had poor results, so I stopped using or recommending them. Once I started on TFP and another forum I frequent (about a year ago), I started hearing about Ahhsome. I read threads, watched videos, chatted with @dlleno and @Ahhsomeguy, and was convinced. But I had never used it myself...
So I reached out to Ahhsomeguy and made him a little challenge. I proposed to run his product in this tub (after I complete repairs) then cut open a pipe and look. Forget scientific test numbers, I am from Missouri, the Show-Me state. So show me. I had ahhsome delivered at my house 2 days later. He must have shipped it priority, or something.
I will keep you posted on the repair status and test results with pics. I am kinda excited, but the tub has ALOT of leaks, so it may be a bit...
So here it is:
