I just received a detailed equipment list. What would you change? This is for a 35x21 geometric pool with 13x6.5ft sun deck. It will also have a raised 7x7 spa with spillover into the pool below. Depths 3.5-7 ft and approximately 27.5K gallons.
- I've already asked to requote with the VS pump instead of VSF based on my reading here
- I've read about making sure you get the Intelliflo unions. Are these the right ones?
- Should I consider Raypak to replace the UltraTemp Heat Pump or the MasterTemp Natural Gas Spa Heater?
Item Detail | Qty |
Pentair; IntelliFlo(R); IntelliFlo(R) VSF; Variable Speed & Flow Pool & Spa Pump; 208-230VAC; 50/60Hz; 3200 Watts Max.; 1 Phase | 2 |
2 Pole Circuit Breaker; 20A - Intelliflo | 2 |
Pentair Clean & Clear(R) Plus CCP520 Cartridge Filter; 520 sq-ft; 150 gpm | 1 |
Pentair Ultratemp(R) 140 H/C Almond Plastic High Performance Heat Pump; 140000 BTU (Heat)/80000 BTU (Cool); Digital Control; Titanium Tubing; 230 V; 1 PH; 60 Hz | 1 |
Pentair 522041 IntelliCenter Load Center; With Salt Chlorine Generator Support | 1 |
Pentair 521914 IntelliCenter i10PS Pool / Spa Personality Kit | 1 |
Pentair Intellicenter 522475Z Wi-Fi Antenna (primary client bridge) | 1 |
Pentair Intellichlor(R) IC60 Salt Chlorinator Cell with 15 ft Cord For Intellichlor(R) Salt Chlorine Generator; 60K gal | 1 |
Pentair Sta-Rite(R) SwimQuip(R) ABS U-3 Top Performing Inground Skimmer with Lid and Frame; White with Tan Lid and Frame; 2 Inch x 1-1/2 Inch NPT Reducer | 2 |
AquaStar Pool Products 10AVR103 Round Anti Entrapment Suction Outlet Cover; 10 Inch; UV-Resistant Engineered Polymer; Light Gray | 6 |
CMP 25575-509-000 Water Stop Adapter Fitting; 1-1/2 Inch FIP x 1-1/2 Inch Socket; Clear | 11 |
Super-Pro; 25552-401-000 Hydrostream Fitting; 1-1/2" MPT; 1" Opening; Gray | 11 |
Super-Pro Hydrotherapy Jet Body with 4" Nozzle for Spas | 6 |
Air supply of the future inc 6315241 1.5 HP, 220/240v, Silencer Air Blower | 1 |
Pentair IntelliBrite(R) 5g Underwater LED Pool Light; 12 V; 26 W; 100 ft Cord | 2 |
Pentair IntelliBrite(R) 5g Underwater LED Spa Light; 12 V; 18 W; 100 ft Cord | 1 |
Hayward SP0600U DuraNiche(TM) PVC Large Lighting Niche; 3/4 - 1 Inch Socket; 45 Deg; Top or Rear Mount | 2 |
Pentair PVC Small Niche For Concrete Installation/SpaBrite(R) and AquaLight(R) Light | 1 |
Pentair Transformer; 12 -14 V; 300 W | 1 |
Pentair Transformer; 12 -14 V; 100 W | 1 |
CMP 25503-001-000 Bubbler For Natural Wonders Gunite Pool Fountains; 1-1/2 Inch MIP; Gray | 3 |
CMP 25577-231-000 Natural Wonders(TM) Waterfall; 24 Inch; 6 Inch Lip; Back Feed; Gray | 2 |
Pentair Water Pool And Spa Inc; T40FB; Autofill With Fluidmaster Valve | 1 |
Pentair Water Pool And Spa Inc; 2" - 2.50" 3-Port CPVC Diverter Valve | 3 |
Pentair Water Pool And Spa Inc; 2" - 2.50" 2-Port CPVC Diverter Valve | 8 |
Pentair CVA24 Valve Actuator For 3-Port Valve; 180 deg | 1 |
Super-Pro; SP0801-20H2 Check Valves; Slip x Slip; CPVC; 1/2 Lb. Corrosion Resistant Spring; 2" Slip; Heat Tolerant | 1 |
Pentair Water Pool And Spa Inc; 263042; 2" - 2.50" Straight CPVC Check Valve | 1 |
Super-Pro; 21063-200-000 Above Ground Pool Pump Union Fitting; Hi-Temp; 2" MIP x 2" Slip (200-906) | 4 |
Pentair MasterTemp(R) Digital High Performance Low NOx Pool and Spa Heater; 400000 BTU; Natural Gas | 1 |
30" CAPPUCCINO IN POOL/SPA TABLE (HRL-96-0057) | 1 |
